Replaced fuel line now truck won't start.
dmorris0821
Virginia
Ford Ranger STX
I replaced fuel line from tank to filter and now truck won't start. Fuel filter is working. Any ideas on what it can be? Any help is greatly appreciated. TIA
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Was the line leaking?
Does the pump run?
dmorris0821
Virginia
Ford Ranger STX
Yes, the line was leaking and the pump runs when I turn the key to the on position.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Is the new line kinked?
Did you put a pressure gauge on it? What was the pressure?
dmorris0821
Virginia
Ford Ranger STX
No, line is not kinked and I did not put a pressure gauge on it. I disconnected the fuel line from the filter. Turned the ignition on, fuel pump turned on but no fuel came out.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Well it can only be one of two things...
You're out of fuel
Your pump is shot
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
all the times i have bought a used car that had that issue and is why the people were selling, it was they were out of gas or the pump is shot.
well, on diesels it is normally they didn't prime the fuel injectors when they ran out of gas but thats a little different
dmorris0821
Virginia
Ford Ranger STX
Not to sound stupid but if I can hear the fuel pump activating, can it still be bad? I do have gas in my truck(1/4 tank)
8,370
As Uncle Gump said
You're out of fuel
Your pump is shot
1/4 tank based on what?
If that is based on the gauge, then you do not know what is in the tank
Chased my tail a few times on faulty gas gauge
Add some gas to the tank, or rock the truck and listen for the 4-5gal(1/4 tank) sloshing around inside
Pump running is a good sign its working, getting 12volts and ground
But the "proof is in the pudding", no fuel coming out is either a blocked hose or a bad pump section, but electric motor works
gaz
657
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
@dmorris0821 ,
It may have helped if you had filled the new fuel filter (as much as practical). Regardless...turn the key on to run (not start) for 5 seconds, then off for 10 seconds. I do this 10x to re-prime the fuel system.
After the 10x, I go-to your fuel system bleed/pressure test valve port on the fuel rail and check system pressure; if you do not have a gage, just see if 45 lbs or so worth of pressure atomizes fuel into the air (a small plume of fuel mist).
Also, these fuel filters are directional.
