replaced suspension, kinda stiff.
88workcar
49
Pierre Part La.
Ranger XL
Friday morning I replaced all of the front end parts. The truck rides like it is brand new now. (rear shocks also) But I have a question, When tightening the upper arms, at the frame rail tabs, I tighten the hell out of the bolts. The front end was up on jack stands so the whole assy was stretched out as far as the shock would allow hanging down. When done it seems that the truck sits a little higher than before. I do understand part of that because every part of the suspension was shot. Now that I am done and going get a alinement I noticed that if I push down on the hood of the truck it doesn't have much bounce to it and has me wondering if I over tightened the upper arm bolts and it's actually holding the truck up in a elevated position?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,501
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
The upper arm bushings have a working range... if you had the suspension fully dropped when you torqued them up... they are probably holding up the vehicle to some extent.
I typically put the weight of the vehicle back on the springs/suspension before torquing things up.
Bird76Mojo
1,265
IL
Everything should be tightened to spec when the truck is at ride height, supporting itself. Otherwise you will wear out parts prematurely.
88workcar
49
Pierre Part La.
Ranger XL
Thanks, will adjust today, alinement appointment on Thursday.
