replacing cluster needles
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
When I go to replace the needles on my cluster, should I mark them and replace them so that they read true when I put them back in?
kjt
memphis tn
ranger xlt
8,370
For the electric speedometer you often need to do this: youtube.com/watch?v=WVz6ilGiTBY
Hook it up to AA battery and put needle on to read 72MPH, but test it before you remove the needle and use same battery when you put needle back on
Bird76Mojo
1,265
IL
I DO NOT RECOMMEND DOING IT, but I set out on a long stretch of highway with no traffic, set the cruise at 55mph indicated by GPS, had my buddy steer the truck, and shoved the needle on at the 55mph mark. Worked for me..
This was after a cluster swap along with a tire size change. It's close enough at other speeds to not be any worry to me.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
My needles are painted on...
Plug your cluster in and turn the key on, then set the needles at the zero point.
I've done this once or twice.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
Thanks ^^^^
