Running rich
forzainformer2
Found a new problem on the truck... fixed the upstream O2 and the check engine light turned off for two days, its back on and now the truck is running rich, had a friend hook up their scanner to it and when you start the truck it says the everything is fine till you put the truck under load then the injectors stay pouring fuel like my foot is to the floor.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
What are the actual code(s) associated with the check engine light?
8,370
What year 4cyl, there was a BIG change in 1995 and then again in 1998
So you are getting Black smoke out the tail pipe?
That's Rich running
Rich Code is NOT Rich running it denotes a computer calculation error, same as Lean code does
Gas pedal does not control fuel flow, computer does, gas pedal is an "air pedal" on fuel injected engines.
As you add more air, with the "air pedal" computer will add more fuel :)
forzainformer2
That's Rich running
97 4cyl, the guy had his showing live data and the fuel rate was through the roof from what, he was telling me. Ive been cruising it for three days and been getting 7mpg.
8,370
Thats the STFT(Short Term Fuel Trim) showing HIGH positive numbers, like +25% and above
Which shows up as a LEAN trouble code
If you got a RICH code then it would be STFT -25%
But the 7mpg means engine is actually running RICH not Lean, so really really would like to know the numbers AND the codes?????
But from the 7mpg I would say to check the Fuel Pressure Regulator(FPR) on the engines fuel rail.
Prior to 1998, Rangers used a Return fuel system, running 30psi fuel pressure and an FPR.
The FPR has the fuel Return line and a vacuum line attached, the FPR has a rubber diaphragm inside that can crack and leak, the Vacuum hose will suck that gasoline into the intake causing very low MPG and poor running(Rich code and negative STFT).
Find the FPR, and remove this vacuum hose, check it for fuel, if fuel is in there replace FPR
forzainformer2
I was never shown codes his scanner just said what was setting off CEL like the o2 sensors. I will check the FPR
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
In the future always get the codes. Scanning a vehicle without writing down the codes is like wiping before you poop. :D
There are HUNDREDS of codes, over a dozen just for the 02 sensors. Each one tells a different story. Having a mechanic or buddy say "my scanner said its an 02 sensor issue" is literally useless information.
forzainformer2
Im workin with what im told
