- Dec 5, 2011
- 19
- Fort Worth, TX
- Ford
- Engine Size
- 4.0
I have a 1994 4.0 v-6 and decided to do the Saginaw pump conversion. I went with the 1978-1979 F-350 Super Cab pump, part #AA1 20-6240F from RockAuto(has the aftermarket filter installed). After taking the trouble to remove the stock pump and bracket I found that the Saginaw pump fit without any modification. The pump didn't have the bracket as mentioned in the Tech article, but the bolt holes for the pump lined up exactly with the bracket. It even had the same style mount as the stock pump that I pulled off.
Has anyone else had this experience? Apologies for no pictures, I meant to but then got side tracked when I didn't have to modify it.
