sas new direction
QuakerShaker4242
Avon, IN
4.0l V6
now would i be able to do leaf spring front setup with the f150 dana 44?
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
yes, but why? Coils will flex better, and ride nicer too....and the axles already setup for it, not to mention it damn near bolts up to our trucks....
-andrew
QuakerShaker4242
Avon, IN
4.0l V6
-andrew
are there any coils that can give me 12" of lift. cause i have 4 chevy leafs that i was planning on using but for the size tire i was going to use i wanted a full width axle
wahlstrom1
J-man HD Mech
21
Edmonton Alberta
I'd say use a 7" EB coil (or bigger if you can find them) and lower your coil towers the extra 2"s. I have them and they gave me a solid 10"s of lift.
-andrew
Toreadorranger
5
Sal
-andrew
why do you need so much lift?
wahlstrom1
J-man HD Mech
21
Edmonton Alberta
I rubbed with 33's and a 4" lift, so I figured a 6" would be good then. I then thought with 35's or 36's that if an 8" lift will clear them, then 10" would be good. I'm gonna cut fenders as well, and have no issues about lowering it back down later on if I can.
-andrew
QuakerShaker4242
Avon, IN
4.0l V6
On a D44? Good luck to you, cause your gonna need it.
its not going to be a mall crawler.. buts its not going to be some rockcrawler or beater either. would a dana60 be a better choice?
QuakerShaker4242
Avon, IN
4.0l V6
It's always about how good you are at bargaining and the going price in your area. Also, what you are willing to spend.
i was thinking about $500 for front and rear??
wahlstrom1
J-man HD Mech
21
Edmonton Alberta
You'll spend that or maybe a lil less on rough diffs, then spend a whole lot more rebuilding them and getting them setup for your intended use.
-andrew
QuakerShaker4242
Avon, IN
4.0l V6
For 48's? Yea. That or 2.5T Rocks....:rolleyes:
48's... haha maybe sometime in my lifetime....
i going go go with the 74-77 f150 and the dana 44. that would have the 9 inch rear correct? the ford 9inch info in the tech area didnt specify it that well so i just wanted to check. just get both axles out of the same vehical, convenient.
