seal up dust-cap...
LilBlueTruck
Hey guys,
I did the front brakes a week ago on my 2000 2.5L prerunner (4x2) - new rotors, pads, hardware, etc. I cleaned everything up, regreased all the friction points, and put in a new set of Timken wheel-bearings with inner-seals. As I was finishing up, I went to put the dust-cap on that gets pressed into the hub of the rotor and it slid right in. Apparently the bore in the center of the new rotors is a bit larger than the old rotors. A little annoyed, I used a pair of pliers to bend the outer edge of the cap outward so that it would fit tightly. On the other side, the same situation occurred so I did the same thing. As I hammered the cap in, I noticed a little grease squeeze out, indicating to me that this was not a very good seal. I could go and get a new set of caps but fear that the new ones won't fit either. I do not want dirt or water getting inside the rotor, since this will contaminate the grease and destroy the wheel bearings. I was thinking of sealing the lip up with Indian-head shellac or Teflon-tape or plumber's pipe-gunk, but don't know how well this will work since there aren't any threads and the temperature of these brake-parts can get very hot. Any suggestions? Thanks for your time.
3,614
OEM rotors?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
You can put a smear of RTV silicone on em before you pound em in.
Earl43P
38
Farmington, Pa
Ford F250 4WD
Lordy, just go into any Auto Parts store, hit the Dorman HELP section, and buy the size you need, $5 each.
LilBlueTruck
Yes, OEM style rotors... Not sure the RTV sealant will hold up to brake temps and I don't want that stuff melting and getting into the bearing grease. As previously stated, getting a new set of center-caps is another option, but how will that help if they are the same exact size as the ones I have? Probably will fit the same, but for the lousy $5 a pop, it might be worth a try. I use Permatex copper on an exhaust flange on my car to ensure that there are no leaks, so I was thinking that might work here too. Any other suggestions will be appreciated. Thanks.
