shifting troubles
94redranger
i have a mazda 5 speed that when I shift into second gear i really have to force it hard to get it into gear. Also when I shift from third to fourth it will grind going into fourth it I dont wait about 2 second before shifting into fourth. I heard putting in synthetic ATF could help the grinding issues. Will that also help the hard shifting into second issues? thanks
MAKG
19
California central coast
There isn't any mechanic in a bottle.
2nd gear is the weakest one here. It's very susceptible to long-term forcing by the driver. The fix is a teardown and rebuild, replacing the 2nd gear blocking ring and whatever else might be damaged. This is quite pricey.
A problem shifting into 4th may indicate loose bearings. Something else that requires a teardown and rebuild.
