97Ranger3.0
- Nov 22, 2017
- Reaction score
- 67
- Location
- Florida
- Make / Model
- Ford
- Engine Type
- 3.0 V6
- Engine Size
- 3.0
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 4"
- Tire Size
- 33x12.5
First of all; I'm not sure where best to post this, so if it needs to be moved elsewhere I'm sorry about that!
So, I've got a 1997 Ranger 4x4 3.0 5 speed regular cab 7' bed. I've had this issue since I got the truck 2 years ago and have still not figured out the issue. Basically, there is this annoying shudder/vibration that is most noticeable between 40-45 MPH, any speed slower or faster it is not very noticeable except above 60 MPH where it starts to almost qualify as death wobble. The best way I can explain the shudder at 40-45 is that I feel it most under the seat, it's not a steering wheel shimmy like unbalanced tires. It feels like there is something wrong in the driveline, as it almost feels like the truck is bucking back and forth slightly. It doesn't matter if I'm in 3rd, 4th or 5th or even 2nd; any gear at that speed causes this issue. The vibration gets just slightly worse when braking, but just barely. When the vibration comes back at 60+ it feels more like the original shudder plus something similar to a tire balancing issue so it gets quite wobbly. Also one thing I would like to note is that the shifter will visibly wobble back and forth at those higher speeds. With all that being said, here is everything I've done to the truck worth mentioning. Some of it wasn't necessarily in an attempt to fix the vibration but is worth mentioning to be able to be ruled out (hopefully).
- I've run several different wheel/tire combinations, both unbalanced and balanced at different times, not much difference. I only had one set of studded snow tires that made the problem worse. They made it so much worse that it was unbearable to drive if I had to cruise around 40-45.
- I've checked the pinion angle and currently have it set 2 degrees down compared to the transfer case flange; I will experiment with pinion shims soon and see if it improves with more angle, say 3 degrees or so.
- It has all new u-joints and at this point I've done every single bushing in the suspension, including new motor mounts and a polyurethane transmission mount.
- I don't feel any unusual play in any of the front end.
- I recently had the rear driveshaft worked on because I suspected it was out of balance and this was causing the problem. Upon inspection, the shop found that the slip & spline had too much play, so they made me a new one and a stub shaft for the transfer case end of the shaft and balanced the whole unit. This helped a little, but the problem is definitely still there.
- I'm running rear disc brakes because I swapped to an Explorer rear end, so I don't believe out of round drum brakes are causing the issue which I have heard of in some cases.
- There is absolutely zero play in the transfer case output shaft as far as I can tell from grabbing the flange and trying to move it. However, the transmission is a bit noisy in 4th and less so in 5th, not so much in any other gear.
That's about all that I can think of right now that might contribute. The only thing I haven't done yet is try to get the rotors turned. I don't suspect that warped rotors could cause this vibration because from what I've read that should only cause vibrations during braking. But, when I got the truck it had brand new front brakes so I've never touched them; so it is one thing that is a slight possibility that I haven't done. At this point, I'm not sure what else could really be left causing this issue so I plan on taking all 4 rotors to get turned today just to see if it changes anything so I can rule it out as well (or maybe I'll get lucky and it'll fix the problem).
Otherwise, should I take my driveshaft back to the shop and have them completely rebuild it? The rest of the driveshaft has what I'd consider minor surface rust on it and they didn't seem to come across any problems with it other than the slip & spline when they balanced it. Also, I was running a crusty junkyard driveshaft in my truck while they were working on my driveshaft and it didn't seem to change the shudder issue either.
I enjoy driving this truck, and have put a lot of work into it fixing and improving it over the years but this one issue is very frustrating. I tend to avoid highway driving because of this issue, but I would like to get this issue sorted so I don't have to do that any more because that is honestly just annoying and wastes time. Has anyone experienced anything like this? Is there anything I'm overlooking? Any input is appreciated.
