- Aug 26, 2008
- 13
- 1994 Ford Bronc
- Engine Size
- 5.8v8
- My credo
- Failing is easy. Everyone can do it.
Ordered in a new slave for the M5OD.
Brand is LUK.
Along with the flywheel and clutch complete setup.
The slave cylinder was a combo of the release bearing and slave. New in box.
The slave was bouncing around the box a bit, but I can clearly see the release bearing has a wear pattern already in it. (Along with more then a few scratches) It's smooth as silk for spinning,...but this concerns me as I'd rather not have to drop that trans a 2nd time. (And if anyone's bothered to read the other thread? This job has been a headache beyond what I expected.)
The inlet port was covered with the red 'sock'. I can clearly see some black little specs and fluid traces. The bleed screw also has a bit of 'crust' on the bleed hole area. Not bad, that could just be from sitting around on the shelf for a while.
I've emailed Rock Auto on this...as it wouldn't be the first time I've gotten someone's return part when they scammed Rockauto. I nicely explained that I'm not sure if this wear was part of product testing...or someone installed it...the part didn't work? So they boxed it up and returned it and then I got stuck with it.
2nd question: Is the pilot bearing for this setup (1995 Explorer Sport 4.0 OHV.) in the engine crank, or the flywheel? We purchased the new flywheel as well, and it looks like where it mounts to the crank? There's already a pilot bearing in it's place! (That part is still in the shrink wrap and protective stuff...so I didn't get a close look)
S-
Brand is LUK.
S-
