myagi
- Sep 22, 2012
- 0
- Ontario
- Mazda
- Engine Size
- 4.7
Well. I'm slowly getting all the gremlins out of my 289 powered B3000 but I'm stumped again by the sluggishness of the engine.
First the specs;
1) rebuilt 289 C code with stock heads (new Comp Springs) mild porting on intake and exhaust
2) Comp Cams DEH275 grind (dual energy) camshaft - longer duration - loping idle
3) stock Autolite 2100 2 barrel carb on stock intake
4) stock exhaust manifolds from 70 F150 (for now)
5) stock EFI fuel pump regulated with Holley bypass style regulator down to 5 psi for carb
6) new GM style HEI distributor with new Accel wires and Autolite plugs (plugs are all light brown after 300 to 400 miles)
7) vacuum shows consistant needle at 15 Hg - low idle
8) Compression 140-150 psi on all cylinders
9) Timing set at about 10 degrees initial. Shows around 20 if I raise rpm to 2500.
The engine fires right up and idles well. I'm getting decent mileage on highway and accelerates normally but if I mash the pedal, it feels very slow to respond. When I get up to 45 mph or so it feels like I'm driving a 4 cylinder. No top end power whatsoever
I'm leaning towards either inadequate fuel supply, poor timing curves, or plugged carb.
Any ideas where to start first
First the specs;
