Smoke Test
15
Redondo Beach
Ford Bronco 2
Hello as per my last post, (https://tinyurl.com/4f38k386) I have performed a smoke test to test for vacuum leaks by making my own version of a smoke machine from a few videos I found online. I pumped it into the car and found that, while the engine is off, the EGR was emitting a TON of smoke. My question is, is it supposed to do this? Or does this tell me that the EGR is busted and should be replaced? Any advice would be appreciated as I'm still learning how every part of my car works.
superj
2,706
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
I think you have something wrong than. I dont think you should get smoke from anything
15
Redondo Beach
Ford Bronco 2
@superj I think you misunderstand. I made a smoke machine using a soldering iron and baby oil to put smoke through the system in order to find any potential leaks. When I did I found the EGR was leaking smoke. My question is, should the EGR be leaking air when it's off?
Josh B
1,988
Oklahoma
Why do you have all the blue gasket material in the hot zones?
alwaysFlOoReD
5,135
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I think it's supposed to open under high vacuum and feed exhaust into the combustion chamber. That would lead me to believe the valve is closed when not running, so no smoke. But this is just an semi-educated guess.
lil_Blue_Ford
6,228
Butler, PA, USSA
4.9L
I think I’d eliminate the EGR. 88-92 Rangers and Bronco II with the 2.9 had no EGR, so by blocking it off and swapping to the “newer” computer is a legal “upgrade” even though it eliminates an emissions part. But that’s me…
15
Redondo Beach
Ford Bronco 2
@lil_Blue_Ford That would be nice, however, I live in CA and they're a bit more fussy about emissions. Id rather not risk that but just fix my stalling issue.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,789
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
There shouldn’t be any smoke coming out of the EGR where it bolts on or from the pipe coming off the exhaust manifold. As far as if any smoke should be coming out od the valve into the intake, I’m not sure when it’s supposed to be open and when it’s supposed to be closed.
