A4LD_Nghtme
- Nov 7, 2021
- 53
- Twin Bridges, CA
- Bronco II XLT 4
Where is the computer located? Passenger wall under glove box? I can get that done!
also, I did a smoke test. Was wondering if smoke should leak from oil cap and bottom of air cleaner box? Air cleaner box has two holes in bottom of it that I assume are for moisture to escape but not sure. Other than that I don't see smoke coming from anywhere else so I think that confirms vac leak.
I also did a vac guage test and was getting steady needle 17-18 in hg when first started back up after warm, then the idle started going haywire and it drop to around 15 in hg and the needle was extremely unsteady. Maybe I have a clogged injector even though they are basically brand new accels
