Dustin_89BII
- Jun 5, 2022
- 23
- Oregon
- Bronco II
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
Hi folks,
I’d love some help with this one. None of the other posts I’ve seen have quite address what I’m experiencing.
I just rebuilt and reinstalled the 2.9 in my 1989 bronco II.
I got through initial engine break-in well and now I’m trying to set base timing (10 degrees advanced with spout removed on a warm engine). However, when I removed the spout the engine dies immediately. No stutter, no slow die with cascading rpm, just instantly like the key was turned off.
The engine runs well and sounds good.
The tach gauge in the dash shows 750 to 850 RPM at warm idle, sometimes up to 950. And an auxiliary digital rpm gauge connected to a plug wire was showing more like 1000 RPM, so I don’t know why there is a discrepancy there. But all that is to say that the running RPM is in that range when I pull the spout connector.
The engine is between 200-250°, depending where I am the laser on the block & heads.
the TPS reads 5 v continuous power and goes from 0.86 v steady up to 4.6 v on the throttle test. No flat spots that I can see.
Also, the warm engine will die instantly when I remove the IAC connector.
Using a timing light when the engine is idling around 850, I’m getting 25 degrees before tdc if I’m reading it right. So I think I’m pretty close on timing. Correct?
I’ve pulled codes and gotten 11’s, then pulled later and got “C 63 tp circuit below minimum voltage” so perhaps there is some kind of intermittent connection issue with the TPS, but I don’t know what else to test on the tps or how to.
the IAC is in the 11-13 range. It isn’t dirty, and It opens with 12v battery power is applied to it, and/but it kills engine when I pull the connector.
Thanks for reading!
Dustin
Thanks for reading!
Dustin
