howdisrespectful
- Mar 12, 2021
- Reaction score
- 2
- Location
- PNW
- Make / Model
- Ranger 4.0 OHV
- Manual
Hello all I’m a newbie and am looking for some advice/tips/. I am the new owner of a 1991 4.0 ohv XLT 4wd Ranger and I’ve got some trouble codes.
the engine has a rough idle and will get very jerky when passing 3k rpms in any gear.
Code 23 is for the throttle position sensor and after some research this is what I’ve found:
there is an aftermarket TPS on (Standard Motor Products) and its voltage reads .36v at idle and 2.2v at wide open throttle. I understand that this is well below spec. I also happen to have the original Ford TPS so I plugged it in and it read .24v at idle and 1.89v at WOT.
I am planning on buying a motor craft TPS and replacing it however I was wondering if there was another reason which would cause low voltage that I am missing.
Code 22 is for the MAP/BARO sensor and this is what is really confusing me. After searching the forums I learned that some rangers of my era don’t come equipped with either and instead have a MAF sensor only. I examined the location where the MAP/BARO would be and there is only a loose connector and a plastic cover over where the sensor would be. It is very professional and looks to be from the factory.
could my MAF sensor be giving me the code 22? I have tried cleaning the MAF with iso alcohol and a q tip but there was no change in performance.
also I recently replaced the cylinder heads and fuel injectors but the problems were present before any work was done, and they have not changed whatsoever after work was completed. and I replaced ALL battery connection terminals positive and negative as well as installed a new battery and the issues are identical before and after work was completed. Any advice AT ALL would be appreciated!! Thanks!!
