JoeLeFou
- May 30, 2023
- 54
- canada
- Ford ranger
so I'm making this post hopefully to help others that might have this issues in the present or the future where the starter might start to grind when starting the truck or does grind when you try to start it. Personally I couldn't get it to start at all since the bolt holes where stripped to shit so that would be to check
using Heli coils, time-sert, locking insert or just use a bolt that goes all the way and 2 nuts to solve that part of the problem (don't forget that you need to tighten the bolts real good so that they don't come loose and 'free' the starter)
Also gonna need to use some lock washers and/or thread locker, blue works great. I've learned that Permatex released some orange thread lock "3x stronger than blue" but you can remove the bolts without heat unlike the red one so that might be good too.
okay now for the starter we'll need to get a 10 tooth gear
personally I've ordered on canadian auto part but otherwise the part number is E6FZ-11350-A or also E6FZ-11350-AA, you should be able to find it on ebay or some parts store.
you'll have to disassemble the starter to replace the 9tooth for the 10 tooth drive FYI you might have to file down the shaft where the C clip goes as there might be a lip that prevents you from putting the new 10T drive in. make sure you don't forget anything while putting it back together.
some people have gotten away with putting a 4.0L starter but you'll have to run some wires straight back to the starter for the solenoid since the contactor/solenoid for the om is under the hood should be right next to the battery.
if I missed something or if you have any feed back or more info for a starter swap what models would fit please let us know ! hope this helps !
