Speed control
jimsea
Have 2008 Ford van e350 superduty v10 Speed control will not turn on, can not find in the
Owners manual a fuse location. Is there another location or a relay?.
8,374
Speed or Cruise control doesn't have a separate fuse in your 2008, its run thru the PCM(engine computer)
Usual causes for cruise to stop working is brake pedal switch or brake pressure switch fault
These are switches that would turn off Cruise control if it was on
So if one of these switches fail then you can't turn it on
I assume brake lights work, this is not the same switch but its part of that same switch
Not familiar with E350 wiring so that's as far as I can go, but for sure its not a fuse issue
jimsea
Thank you for the information will check tomorrow. Thank you
jimsea
[/QUOTE
Checked both switches and were ok, reset PCM and every thing back to normal and working
fine. Thank you for putting me on the right path
jimsea
Checked both switches and were ok, reset PCM and every thing is now working fine
8,374
(y) Good stuff
