Sport Trac Inspection Going To Be Pricey
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,873
Pittsburgh, PA
2.3 EcoBoost
1.5"
State inspection and emissions due this month. I knew the Trac had a squeaky ball joint, suspect rear brakes, no e-brake, and a fairly constant CEL showing left and right cat codes. Not able to keep the light out long enough to coax it past the emissions test. New Y-pipe and cats. All four brakes and rotors. Don't know what's wrong with the e-brake yet. The ENTIRE front suspension needs to be rebuilt. Every bushing, both UCA's, lower ball joints, struts, and strut bushings, sway bar end links. Basically everything that moves up and down is as loose as the Steelers' defense. Things that move left and right are passable but they say the steering rack is loose and should be replaced soon. Bought new tires two weeks ago. And I already knew the rear driveshaft carrier bearing is blown and that needs to be replaced along with the rear struts. 184,000 miles, this stuff will happen. Guess now I'm going to have to keep it another year or two. :icon_cheers:
85_Ranger4x4
17,998
SW Iowa
Sounds like my '150
Needs tires, upper control arms/balljoints, TRE's and aligned. And then tires..
Similar mileage too.
3,614
I knew there was a reason I got my inspection license back.
But seriously, even if it was mine I wouldn't pass that.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
What's an inspection? :idiot:
rusty ol ranger
2.9 Mafia-Don
7,746
Michigan
177 CID
Sometimes im thankful i live in MI
Bgunner
1,100
Western Mass.
Ford/Ranger XLT
225/70/R15
No inspections is why I loved living in Georgia but I have seen more vehicles on the side of the road in states without inspections than with. Have fun doing your front end rebuild, but if you do your carrier bearing yourself and don't mind taking pics while you do it, I'd love to see how it is done for when mine finally goes. I've done many things but not a driveshaft carrier bearing, not even on my old Yota pickup. My brother did that one because my dad sent it to his shop since I was just learning in school how to pull wrenches then.
85_Ranger4x4
17,998
SW Iowa
No inspections here but I don't want to put new tires on worn suspension stuff.
