- Apr 13, 2009
- 5,096
- Calgary, Canada
- '91, '80, '06
- Ford, GMC,Dodge
- Engine Size
- 4.0,4.0,5.7
- 2WD / 4WD
- 4WD
Hole saws tend to cut larger than the size they say. I'd be leery of using one. I'm pretty sure the new piece should be a slight press fit so the hole needs to be a couple thousands smaller than the new sleeve. You will never get that accuracy with a hole saw.View attachment 36443
lView attachment 36444looks like there is corrosion in the center that will limit inserting the new bushing. I am planning on using a hole saw to cut out that ridge n the center
any suggestions on grease to use and torques to set on the bolts?
Emery cloth and elbow grease.
Don't know torque values off hand.
