rypp77
- Nov 17, 2008
- 1
- Houston
- Ford
- Engine Size
- 2.3L
I have a busy past two weeks with this project.
Problems:
Damaged Passenger Fender
Damaged Passenger Door
Bent Front Bumper
Bend Hood
Bed - Dents on the Passenger Side
Missing matching set of OEM Rims
Busted Back Window
Key Lock won't work
Mechcanical Problems:
Master Cylinder
Slave Cylinder
Fuel Sending Unit
This is my old college truck, a 1996 Ford Ranger. I gave it to my parent and they left it in this conditions. It last ran in 2007 (based off the tags on the window.) The goal is to update the truck and give it a new paint job, Wish me luck.
First Replaced:
Master Cylinder
Slave Cylinder
Clutch
Pressure Plate
Pilot Bearing
New Brakes
New O2 Exhaust Senors, (Front and Rear)
Cleaned up the Mass Air Flow Senor
Also painted the crossmember and driveshaft
Next weekend install this:
As well as paint the frame and install a new fuel sending unit. Maybe get brave and remove the rearend and paint that to.
Problems:
Bent Front Bumper
Bend Hood
Busted Back Window
Key Lock won't work
Master Cylinder
Slave Cylinder
Fuel Sending Unit
First Replaced:
Master Cylinder
Slave Cylinder
Clutch
Pressure Plate
Pilot Bearing
New Brakes
