locovaca
- Jan 26, 2008
- 4
- DeWitt, IA
- Ford
- Engine Size
- 3.0
I'm in the process of piecing my truck back together and have gotten stuck on the starter cable routing. I looked at a JY but they only had a 98+ and the cables on that appeared to go straight down by the battery tray and follow the block to the starter. That routing doesn't seem to make sense on my 93 so I have it running along the fender then crossing the frame and under the steering column. The issue with this is that there is a ground + screw and I can't find a hole to put the screw in to on the frame- there is one but it doesn't seem to be threaded.
Can anyone tell me how the starter cable routes on a 93/94? Don't need pics but if you are able that might help as well.
