z987k
- Jan 28, 2010
- 0
- Portland, OR
- Ford
- Engine Size
- 4.0L
Started off doing thing a number of months ago. Just tapped the starter with something solid and everything was fine. About a week ago, it decided it was through with that and quit starting after the love taps. So I figure it's the starter itself since banging on it made it work. Replaced that, and still the same problem, taps do nothing. So now I'm thinking solenoid, so I get the voltmeter out.
When I engage the starter with the key I get the loud click, presumably the solenoid engaging, but it goes from 12v across the two posts and rapidly drops to roughly 0. After letting off the key, it comes back to 12v. I did this a few times and in the process the small red wire that I think goes to the starter as well got hot enough to melt some of the insulation.
Seems like a solenoid problem, or do I have a bad ground? Maybe the small red wire is grounding out? (not 100% on what that wire does) Where do the three wires that are attached to the fender mounted solenoid go? The bigger one from the battery, the other's I'm not 100% on. It looks like the small one that got hot goes to the starter, but that seems way too small of a wire to be using to crank the starter. (I think it's the one that has the spade connector)? What about the other wire off the solenoid? Ground?
Thanks for any help.
