Starting Issues 2.9l 4x4 1986 Ranger (auto)
rusty ol ranger
2.9 Mafia-Don
7,601
Michigan
177 CID
Whens the last time you put plugs in it? If the coolant sensor was bad it was probably running pig rich and coulda fouled a few plugs.
paulschmitz82
Germany
yes it ran rich, but replaced the plugs some weeks ago so they‘re brand new
rusty ol ranger
2.9 Mafia-Don
7,601
Michigan
177 CID
Hmm....could be plug wires, dist cap, or worst case compression. You may even have injectors sticking closed on those cylinders.
paulschmitz82
Germany
compression is fine, everything on the engine itself is brandnew it just got rebuilt.
Injectors are also new, dist cap and plug wires aswell.
2011Supercab
469
Washington
Toyota Tacoma
Just because it's "rebuilt" doesn't mean the compression is fine, Have you verified it?
paulschmitz82
Germany
yes i did, i measured the compression and it‘s totally perfect
rusty ol ranger
2.9 Mafia-Don
7,601
Michigan
177 CID
Try to verify which cylinders are misfireing, pull each plug wire indvidually while it idles untill you dont notice a difference in engine tone/roughness.
Being its batch fire you may have a wireing or ECM issue if all the parts are new.
Curious....what were the PSI numbers on compression?
