Aragorn
- Sep 11, 2007
- 0
- Florida
- Ford
86 2.9:
My 2.9 recently has been hard to start. It cranks fine and sounds like it always has when you turn the key, but once you let go, it dies. It usually takes between 2 and 4 cranks and then it just decides to work.
The scary part is, on occasion the engine will suddenly cut out. It has happened 3 times, each one the second I hit a big bump or pot hole.
It has absolutely no problems accelerating, idling, or just keeping speed. Only starting and when it hits a large bump.
The starter is new (but that obviously isn't causing the cutting out).
The canister fuel filter is about a year old.
My prediction is a fuel delivery problem, which could be completely wrong. It seems to me like it can't get enough gas when starting, and it may be having the flow interrupted when I take a major bump. If this is the case, I don't know what to look into (fuel pump, filter, injectors, etc.).
Thank you guys so much for any help you can offer.
Nick
Nick
