stepside bed 2000 ford ranger fiberglass?
smitty2855
ny
3inch body lift
question is I have a 2000 ford ranger stepside bed are the sides fiberglass or a fiberglass mix? and can you just paint them? and do I need to paint the back sides too? can I just fill small imperfections with fiberglass bondo with hardener? have experience painting metal but not fiberglass.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
647
Central Indiana
I believe that technically it's a composite known as Sheet Moulding Compound (SMC) but it can be repaired and prepped for paint the same as fiberglass would.
98 red ranger
near Tampa, Fl
2.5
Rear bed side was damaged on mine when I got it. ground & repaired w/ resin & f-glass, finished w/ bondo. primed & painted just like I would metal.
smitty2855
ny
3inch body lift
I am talking about under the bed and the backside of the bedsides.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
you're confusing us a bit on that one. you mean that big space between the fender and the bedside?
the only parts that are fiberglass are the outer fenders. the inner parts/bedsides, bottom, front wall, tailgate are all plain 'ol steel.
I don't think the backside of the fiberglass fenders are painted at the factory.
91stranger
512
Gets Mo Chicks
Did you try holding a magnet to it? Magnets don't stick to fiberglass so that would be the obvious answer.
smitty2855
ny
3inch body lift
I already know the the besides are fiberglass and I know the backside was not painted at the factory the question is has anyone ever painted the backside and if they did what would you use?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I'd use paint.
