Still starving for fuel
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
On my F150 I pulled the injectors out, soaked them in a bucket of gumout injector cleaner over night and cleaned them. hooked them up to power to make sure they click. reinstalled with new o-rings, changed the fuel filer and have run 3 tanks through both tanks with lucas fuel system cleaner. I am still starving for fuel like the fuel pumps are not keeping up.
can I blow compressed air back through the fuel line to blow any junk away from the pick up tube or is that a bad idea?
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Yea thats a pretty bad idea... Have you replaced the fuel filter? Are there any codes? What are the fuel trim numbers? What is the fuel pressure at the rail?
alwaysFlOoReD
5,123
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Buy or borrow a fuel pressure tester. I just went thru this, my pump would initially put out 40 lbs but fairly quickly drop to below 10lbs. I'd get a few miles down the road then start losing power and die.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
I replaced the filter yesterday, no check engine light and when I pull the codes with a scanner I dont get anything except an O2 code which I assume is because its running lean. going to pull the spark plugs tomorrow and see just how lean its running.
spent my whole paycheck on brakes and filling the tanks so no money for a fuel pressure gauge until next friday.
ericbphoto
Overlander in development
16,667
Wellford, SC
3.0L
6"
How old is the truck? Often, there is a filter on the pump suction (commonly called a sock). So you really shouldn't be getting any big trash in the lines that could be removed with compressed air. Does your last call auto parts store have a fuel pressure gauge in their loaner tools inventory?
Ozwynn
200
Berrien Springs, MI
RE Interceptor
the truck is a '90 with a 5.0L. I dont have the deposit for the fuel pressure gauge until Friday.
ericbphoto
16,667
Wellford, SC
3.0L
6"
I've had weeks/months like that. Wish I had better info to fix your problem.
Yeah, never blow compressed air into the fuel tank. It can be unsafe.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
I'm pretty sure I'm going to have to pull the bed and clean the pre filters and and get the tanks steam cleaned. but it was running perfectly fine on the rear tank until Janurary. now its like the rear tank fuel pump is dying
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
O2 codes go with a rich or lean condition. And there are about 50 codes related to the o2 sensors... So that code is important.
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
have you flow tested the system? should be able to divert fuel into a gas can and run the pumps.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
I though of this, but I have no idea what the fuel flow should look like if its working correctly
Ozwynn
200
Berrien Springs, MI
RE Interceptor
50 O2 codes on OBD1?
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
Oh nevermind your right.
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
speculating here,,, if you get a lot of fuel that would mean there are no restrictions in the system. filling a gallon in 5-10 minutes is more than the engine would consume at full power.
if it flows good, then the issue would be maintaining pressure at the flow rate.
is it a circulating or dead head system?
