Straight axle swap
danger03ranger
Birmingham, AL
Just sitting here thinking. I know someone has done this. thought about putting a straight axle under my 03 ranger. What straight axle would fit best to match up with the stock rear end. would a Dana 35 be the same length? and the best bet to keep my rear end? and if anyone of you have done this what a was involved besides axle and spring brackets and spring?
Just wondering and dreaming a little. Thanks for the info.
chico4554
CT
use a waggy front D44. Im not sure on the years, but i am sure that there is plenty of info in the stickies at the top of this section
stegomon
20
auburn/minot maine
fords and only
every axil will have a diffrent bolt paturn then you have....and i hear you are lucky to get out away with an sas less then a $100o....and in your case you have alot of fab work
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
For wagoneers it's best to use the 80-83, and 86 and up. (Thats what was told to me on another thread.) It may be a year or two off.
I'm plannin on swappin in leafs up front in my '00. A lot cheaper and easier then runnin coils.
The engine cross member needs to come out too. If you look in the SAS truck gallery, Ryan somethin or other did a really clean swap on his 98 usin a waggy 44. His car domain page has some great pics of the swap and the work involved.
4LO 4.O
Augusta,Ga
jeep's have the same bolt pattern as your truck, 5x4.5.
Toreadorranger
5
Sal
I hope your not talking about that god awful ranger with the Huge lift. Please do not refer people to him as a good example. His ranger and bronco2 are death traps.
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
Well sorry then. I've only seen his Ranger. I'd never lift as high as he did, but his pictures do show a good example of what all is needed and done during the swap.
And 4Lo 4.0,
JEEP TJ- WRANGLER
Production: (1997- 2006)
Identifying Characteristics: Round headlights, tailgate opens to side, with spare tire.
Windshield Width: 55”.
Suspension: Coil spring suspension front and rear.
Wheel Bolt Pattern: 5x4.5”
Wheelbase: 93.4 inch
JEEP YJ- WRANGLER
Production: (1992- 1996)
Identifying Characteristics: Rectangular headlights, tailgate opens to side, squared off rear sport bar support.
Suspension: Leaf spring suspension, front and rear.
JEEP WK- GRAND CHEROKEE
Production: (2005-2006)
Identifying Characteristics: Curved headlights, V styled grill, unibody style construction.
Windshield: Curved Glass.
Suspension: Coil spring front and rear.
JEEP WJ- GRAND CHEROKEE
Production: (1999-2004)
Identifying Characteristics: Curved headlights, slotted tail lamps, V styled grill, unibody style construction.
Wheelbase: 105.9 inch
JEEP KJ- LIBERTY
Production: (2002-2006)
Identifying Characteristics: Round headlights, rounded flared fenders, Classic Jeep style grill.
Wheelbase: 104.3 inch
JEEP ZJ-GRAND CHEROKEE
Production: (1993-1998)
Identifying Characteristics: Rectangular headlights, rounded fenders, unibody style construction.
Suspension: Coil spring front rear.
Wheelbase: 105.9 inch.
JEEP YJ- WRANGLER
Production: (1987-1991)
Identifying Characteristics: Rectangular headlights, tailgate opens to side, diagonal rear sport bar support.
JEEP XJ- CHEROKEE & JEEP WAGONEER (DOWNSIZE)
Production: (1984-2001)
Identifying Characteristics: Rectangular headlights, squareish classic Jeep lines, available in 2 and 4 door models, unibody style construction.
Suspension: Coil spring front and Leaf spring rear.
Wheelbase: 101 inch
JEEP MJ- COMMANCHE (DOWNSIZE PICK-UP)
Production: (1986-1993)
Identifying Characteristics: Based on the XJ Available in long and short bed versions, squareish classic Jeep lines, unibody style construction.
Wheelbase: 113” w/6ft bed, and 120” w/7ft bed
JEEP SJ- FULL SIZE CHEROKEE, JEEP WAGONEER, & JEEP PICK-UPS
Production: (1962-1991)
Identifying Characteristics: Full size wagons available in both 2 door and four door versions and pickups in both long and short wheelbases.
Windshield: Curved glass.
Wheel Bolt Pattern: 5x5.5” thru 1973 on Jeep Cherokee, Jeep Wagoneer and ½ ton trucks (J10), 1974 and later 6x5.5”, J20 8x6.5
Wheelbase: J Trucks 116-131 inch, Wagons 109”
JEEP CJ7
Production: (1976-1986)
Identifying Characteristics: Round headlights, tailgate opens down, bottom mount windshield wipers, and factory sport bar.
Wheelbase: 93.5 inch
JEEP CJ8-SCRAMBLER
Production: (1982- 1986)
Identifying Characteristics: Extended version of the Jeep CJ7, available as mini pick-up half cab, or full cab.
Wheelbase: 103.5 inch
JEEP CJ5 (2nd generation)
Production: (1976-1983)
Identifying Characteristics: Round headlights, bottom mount windshield wipers, and factory sport bar.
Wheelbase: 83.5 inch.
JEEP CJ5/CJ6 (1st generation)
Production: (1955-1975)
Identifying Characteristics: Round headlights, bottom mount windshield wipers, and windshield near straight up.
Windshield Width: 59”.
Wheelbase: 80.5 inch thru 1971, 1972 and later 83.5 inch
JEEP CJ6
Identifying Characteristics: Extended version of the Jeep CJ5. Round headlights, bottom mount windshield wipers, and windshield near straight up.
Wheelbase: 100.5 inch thru 1971, 1972 and later 103.5 inch.
JEEP C101/C104- JEEPSTER- COMMANDO
Production: (1966-1973)
Identifying Characteristics: Round headlights, Jeep CJ style grille with wide hood thru 1971, 72/73 non-typical, full width grille design Available as full or half cab in either steel or fabric, and as convertible.
Windshield: Flat Glass fixed 59”.
Wheelbase: 101 inch thru 1971, 1972 and 1973 104 inch.
JEEP CJ3B
Production: (1953-1964)
Identifying Characteristics: Flat fenders, with a tall hood 10.5 inches one piece windshield. Bottom mount windshield wipers. Side mounted spare tire.
Windshield Height: 22.5 inches
Wheelbase: 80 inch.
JEEP CJ3A
Production: (1948-1953)
Identifying Characteristics: Flat fenders, one-piece windshield with vent. Bottom mount windshield wipers. Side mounted spare tire.
Windshield Height: 27 inches.
Wheelbase: 80 inch.
JEEP CJ2A
Production: (1946-1948)
Identifying Characteristics: Flat fenders, two-piece swing out windshield. Top mount windshield wipers. Side mounted spare tire.
Windshield Height: 25 inches.
Wheel Bolt Pattern:5x5.5”
Wheelbase: 80 inch.
Adam
PARKINGLOT
St. Thomas, ON
Jeep
5.2
there used to be an old member, "rerard" did an SAS using a waggy D44 on a 98, but he kind....vanished....
Toreadorranger
5
Sal
I talk to him once in a while. He still has his truck. He just doesnt post anywhere anymore.
