it should. the 1350 and 1354 are virtually the same and are all interchangeable. you should have a 1354 in your truck so your swap will be very easy. if you have a electric t-case in your truck now you will either have to cut a hole in your floor or get a floor plate with the right hole for your application(auto or man trans)
They do not. I just looked at my fixed front output 1350 and at my electric 1354. The one on the 1350 is considerably smaller. I dont know yoke/ujoint sizes well at all but its smaller than the 1354 yoke.
I am loading pictures now.
I will see if the yokes are interchangable after that.
There is a catch though. The two drive shafts are different lengths. I do not know if the Ujoint going into a D28 is the same as that going into a D35.
You will want to grab that drive shaft too but you can shorten the drive shaft that you currently have to work aswell by swapping yokes.
I would recommend shortening the drive shaft over using the smaller Ujoint. But that is just an Opinion.
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
