96firephoenix
- Aug 20, 2014
- 0
- Indianapolis, IN
- Ford
I'm looking around and trying to consolidate work on my ranger, into distinct projects. Right now, it needs the clutch and timing belt done.
Clutch has failed, Timing belt is overdue for scheduled change.
I'm trying to find info on what all I "Might as Well" do while I've got the truck torn apart that much.
For instance: When I do the timing belt, I might as well do the water pump while I'm in there. When I do the clutch, I might as well do the slave cyl (obvious one there).
Are there any such lists? I couldn't find one anywhere.
I think it also might be helpful to include easy mods, such as "when you change the clutch, you can swap to a better driveshaft with 1 added step" - Just an example; I did that on my firebird (added step was to get a different DS).
