Summer projects
maskeet
Mazda
What is your truck and what are your projects for it this summer?
1994 B3000
- Fix rear fender rust
-Custom roll pan
-convert to electric fan
-possibly a turbo
swynx
9
lewiston idaho
Mazda
1991 ford ranger, supercab, 4x4
- make custom fenders
- 35" super swamper boggers
- 6" suspension lift
- 3" body lift
- custom light bar's front and rear
- exo skelton
- custom offroad interior
- use steal or diamond plating to protect underneath
Boggin
48
1993 Mazda B2600i (before the ranger years)
- Cranked Torsion Bars 3in
- Rear 3in Spacers
- 3in Body Lift
- 34" Rubbers
- Remove Pan
- Push bar
- Back Rack or Roll Bars
Ranger44
23
Illinois
FORD
4.0 OHV
Collecting parts this summer. Hopefully the build will come next summer. Getting an exploder rear end soon, some exploder leafs, just got 97' dual piston calipers for the front(along with the proper brackets and knuckles). Looking into getting a 3.go and 5spd swapped in or look for a new truck as a platform and part my truck out.
injun_ben
Northern Minnesota
Mazda
1994 Mazda B3000 x cab 4x4 3.0 5 sp
1. repainting my bumpers(fix the rust)
2. new rubber(i hate road tires!)
3. fix quarter panel rust
Already got my cab lights put on and wired in!!! Check one off my to do list!
maskeet
Mazda
fixing your rear quarter panels?
injun_ben
Northern Minnesota
Mazda
both need the rust fixed...the ole mazdas starting to show her age...plus a spot on the rocker panel
BlackBII
Ranger Custom
Truck of Month
983
UT
1990 BII
5.5 suspension
33's New LTB's!
Lockers front and rear, 4.56's
4.0/M5OD Swap
(All the parts off the wrecked one, going onto a newer nicer one, still black tho:icon_thumby:
maskeet
Mazda
i got that prob with mine too. how are you fixing it?
im cutting it out, and putting new metal i think.
mkpecor
black diamond W.A.
ranger 4x4
2.9
88 ranger super cab, lockers,gears, winch, EB coils, 302 or 4.0 swap, bobed bed or caged flat bed, toob doors.and thats it, RIGHT now im doing 92 explorer axles front and rear and manual t-case, extended radius arms. should be alot softer ride when done.
Rembrandt
Victoria, TX
Mazda
2.5L
1998 Mazda 2500:
- carb'd 302 swap
- T5 swap
- 8.8" rear swap
- disc brake rear conversion
- new balljoints
- modifying the split bench
- all new bushings
- full frame and undercarriage painting
- making custom front and rear bumpers
- beefing up the body lift
- new 33" tires (haven't decided which yet)
depending on time with all that and money might go ahead and buy and install the Fabtech 5.5" lift.
sbsumerix
Pullman, MI
Mazda
1994 mazda b3000
- 30/9.50/15 Toyo open country a/t
- replace and paint drivers side fender
- maybe roll and brush bars
injun_ben
Northern Minnesota
Mazda
Maskeet ya i mite have to cut out on the rear wheel well because its rusted through about the size of a nickel. the front one still is intact and just needs sanding and painting
Boggin
48
ok, change in plans for me..Screw that stuff i said, Just figure out what wrong with my truck, fix it, trade for ranger, 33's and perfect
maskeet
Mazda
What happened to your mazda?
