swap to newer PCM eliminate Flex fuel?
pjtoledo
2,980
Toledo Ohio
Fords
3.0 2.3
2000 3.0, flex fuel. anybody ever swap in a newer PCM that does not use the alcohol content sensor?
what years had the F-F sensor? did later years just look at exhaust and adjust the fuel accordingly?
a few years ago my F-F sensor failed, I installed the aftermarket bypass for it. problem is, it puts out a signal fixed at 10% alcohol so its always running rich.
I'm wondering if the newer PCM and wiring harness would work.
would this also eliminate PATS ?
Perry
I'm gonna start at the end. A newer PCM will not eliminate PATS. It will only become more prevalent going forward. A total harness swap with a PCM could eliminate the FF sensor.
I have not done this swap, but it really should work.
I think the FF sensor was eliminated in 2001, maybe early 02. It wasn't used long for exactly the reason you put the "cheater" in. It's expensive and breaks more consistently than it works.
The cheater shouldn't be causing it to run rich if it puts out a fixed 10% signal. 10% is the current ethanol levels mandated by the idiots, so it shouldn't be causing a stoich issue, unless the mix you are getting is way off.
The newer ones mainly used the O2 sensors to correct. It just kind of watches the O2s and the injector pulse width and infers the amount of ethanol.
pjtoledo
2,980
Toledo Ohio
Fords
3.0 2.3
Hmm,,, PATS would need a matched PCM, module, and key. The key would probably be the hardest part.
the FF cheater has been there for about 4 years now, not sure what I'll do if it fails.
Here in Toledo we are right on the border of Ohio/Michigan. I think Michigan has mandatory 10% alcohol, Ohio only says 10% max (??) so the fuel mix varies a lot.
Perry
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
Only seven states--Louisiana, Minnesota, Missouri, Montana, Oregon, Pennsylvania, and Washington--have mandates that require ethanol to be blended with the fuel supply.
Louisiana and Washington require ethanol to make up 2 percent of the total volume of fuel sold, while the other states specify E10--a blend of 10 percent ethanol and 90 percent gasoline.
