swap with a 289
Jeeker
5
Ford Ranger ( T
Hi I have a 1994 Ranger 4x4 and would like to install a 289?
also would my 2.3 tranny bolt up to that motor?
any advice much appreciated
3,614
Is this a joke?
Jeeker
5
Ford Ranger ( T
Is this a joke?
No joke, just curious have the 289 available dont want to deal with the 2.3turbo any longer it has issues these days!
plus im just starting out and do not know what my options are ive heard of swaps with 302,351 and maybe more but was wondering about 289?
so no Joke
again any help would be great
best regards
3,614
The 302 block as longer cylinder skirts to help with piston stability at the bottom of the stroke, and some of the later ones starting in the 80s had some better bracing in the casting. Other than that the 289 and 302 blocks are 100% the same and interchangeable. You can even bolt a 302 EFI system onto a 289 block.
So go research the extremely well documented 302/5.0 swap and you will have ALL your answers.
8,374
No, there is no Ranger transmission that will bolt to the 289, especially manuals 1988 and up
Best bet for manual would be an M5R2 from a 1997-2003 F-150 with 4.2l V6 and 4WD
The 4.2l V6 used small block windsor bolt pattern
EvanCole45
27
California
Ford Ranger GT
The 289 is not a worthwhile swap. I'm thinking about doing something similar. The best options as far as V8s seem to go are a 302 or a 347 stroker if you're looking for some higher horsepower numbers.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Engines go vroooooom
Jeeker
5
Ford Ranger ( T
Is this a joke?
Thanx adsm08 I wasnt looking for easy answers just conformation thank you for taking the time
much appreciated! i will do the research : )
Jeeker
5
Ford Ranger ( T
thank you for the advise and the reply much appreciated im just starting out and trying to learn at this point!
Jeeker
5
Ford Ranger ( T
thanx for the advise much appreciated i know sometimes you have to ask stupid questions but im just learning how to do all this so i reached out to the pros!!!!! : )
thanx again
alwaysFlOoReD
5,179
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The c-5 trans found in the very early rangers and b2's can be built to take a lot of torque, and have a removable bellhousing that can be swapped for a bellhousing that will fit.
r1ch999999
33
Hollis, NH
Ford Mustang
So theoretically could someone swap a Windsor into one of these manual transmission F150s and keep the manual?
8,374
Yes, they could, but the 4.2l V6 was rated at 205HP, similar HP to the stock small blocks
Ramcharger90
1,711
N/A na
306, Bcam,
347 strokers have heat issues. Go with a 331 unless you are just running it on a track or going to do some fabrication for a bigger rad
