Swapping from manual to automatic in 1984 Bronco II 4x4
Jacob Segars
Lavonia, Georgia
1984;1992
2.3;2.8
Hello, I am interested in swapping a automatic transmission into my 1984 Bronco II, it is a manual with manual t-case, and the one I'm entertaining putting in there is a c-3 auto with manual t-case. The reason being is I have cerebral palsy on my right side. I have an 1984 ford ranger that doesn't have a title, I'm taking it out of, looking to see what is needed for this conversion ? Thanks
First thing is that the Ranger needs to be a v6 model. The 4-cyl version won't bolt to the Bronco's engine.
Then you will need the flex plate, transmission, shifter and all associated parts, and probably the wiring harness.
4x4prepper
216
Atlanta
You will probably need a new front and rear drive shaft. Have you checked the specs section to see the overall length of the automatic and standard (probably a FM145?) transmission?
