Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
o.k. so there was not a front bar offered from ford?Can't tell you about all sizes but I know the BIIs came with up to a 1" bar on the rear.
Not sure about the Explorer bars but Ranger and BII bars on the rear are interchangable on all of them.
For a front bar on a first gen unless it came with one (I haven't personally seen one yet) your only option bay be aftermarket. On my 84 a second gen bar could not be mounted because what would be the mounting points had non removable jack stand points.
Personally I went with the 1" BII bar on the rear and an aftermarket bar on the front of my first gen. On the aftermarket bar the end links are behind the shock mounts on the inside of the radius arm, and it crosses under the radius arm cross member.
"Removable" doesn't usually include things that can only be removed with cutting tools, especially not in the context of this thread. Cut it off you still don't have the threaded bolt hole that bracket bolts to on the front of the axle. The bracket on a 2wd is slightly different that the one on a 4WD and requires that bolt to mount it. I'll try to get a pic tomorrow to show what I mean.Why not?
Or, we could just agree it was a joke."Removable" doesn't usually include things that can only be removed with cutting tools, especially not in the context of this thread. Cut it off you still don't have the threaded bolt hole that bracket bolts to on the front of the axle. The bracket on a 2wd is slightly different that the one on a 4WD and requires that bolt to mount it. I'll try to get a pic tomorrow to show what I mean.
In order to make it work you would have to cut that stud off flush with the front of the axle, bore out the remaining part of the stud in the beam(don't want to think of how hard metal that is), and then run a tap the proper size through hole. For the average home mechanic that process would not be possible. (Before you make a remark about that with your 4bt swap you can't be classified as average). Even if you could do all of that with it still on the truck, you still gotta disassemble half the front end to attach the brackets to the beam.
