synthetic option for BW1354
2ndSS
10
Illinois
31" on the 02 FX4
can I use Mercon V or Dexron 6 in my BW 1354 transfer case?
mikkelstuff
468
Brighton, CO
Why not use a synthetic transfer case fluid? I used this in my 2002 Ranger:
00t444e
217
Southern OH
Ranger ext cab
Why not just put cheap Mercon rated ATF in it like it calls for?
2ndSS
10
Illinois
31" on the 02 FX4
ok, so after hours of searching and endless discussions, it seems no one is really sure. Even Ford sees to be a lil confused. So I went with Valvoline maxlife full syn.
00t444e
217
Southern OH
Ranger ext cab
I don't know why it's so confusing, any cheap Mercon rated ATF from Walmart or any auto parts store is fine to use.
sgtsandman
Aircraft Fuel Tank Diver
12,652
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
My 2011 calls for Mercon V in my Transfer case. I’m pretty sure it’s a BW1354. So, it shouldn’t be a problem for you.
Josh B
1,986
Oklahoma
Dang, that QT of synthetic is 13 dollars. Farther down on that same page is a 1 (ONE) Litre (LITRE) synthetic gear oil at 35 dollars!
Yeah, I think I'll just go to walmart :D
