T-case ????
#1greenranger
Omaha NE
4.0 v6
ok new ? for you guys could any one through up a pic of how the 1354M shifts on the case..... or has anyone taken a 1354E and made it in to a M?
#1greenranger
Omaha NE
4.0 v6
pillen140
45
winston-salem, NC
there was a vendor on here that had something you had to get underneith and shift it... i think it was called the shifty or something?
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
#1greenranger
Omaha NE
4.0 v6
ya but when your just out drivin and hit mud on a rainy day it would suck to have to crawl under the truck..... does any one know if the M t-cases shift in the same spot as the E's?
TrexMex
6
#1greenranger
Omaha NE
4.0 v6
thankyou that was exactly what i was lookin for!! no just to make one of my own as 300 for a cable and clamp is a rip off.........
slammer67
Salida, Colorado
ranger
you dont need that shiftster thing - if you take off the shift motor, you can shift it with a pair of pliers - it is kindof a good idea though
that one on explorerforum is pretty sweet though - if it works good
somewhere in the past I saw a thread where someone made a manual shift out of an elect shift case - you have to drilll holes in precise locations to make it work plus hope is seals right
not sure where it was though - I'd try searching explorerforum.com or at rrorc.com
easiest way would be to just find a manual shift case somewhere
pillen140
45
winston-salem, NC
actually wouldnt mind supporting him if mine craps out, thats pretty cool. he spent a lot of time and money on something.... not to mention the price of a patent!
Guilius
Millbury, MA
The thing about his product is it will lock into place, so it will not slip out of gear. the electric shift transfer case can be shifted with a pair of pliers once the motor is off, however it WILL pop out of gear......NOT good.
his product stops this.
as for making an electric shift transfer case to manual....your better off just getting a maunal shift case from a junkyard for 200-300 bucks. it's a complete bolt in swap and takes 2-3 hours for the transfer case...and another hour or two to line up the shifter linkage.
if you can, have the junk yard get you the linkage too.
