Tach Install 92 3.0 Manual
mormon92
Pluto
Ford,Mazda
3.0L,4.0L
Hey guys,
i was wondering if you guys could give me a hand with installing a sunpro tach. I found a grommet to run the green cable through the wall and got that connected to the distributor correctly. Now i have three wires left. The black ground wire i can figure out, but as far as connecting the positive and the dimmer wire, im up for suggestions. I dont have a wiring diagram or a test light, so if someone has done this already and could tell me what they did that would be great.
Thanks
fastpakr
2,838
Roanoke, VA
You should be able to use a meter to find a wire that ties into the instrument panel's lighting circuit. For 12v, just tie into the run power wire for the radio.
Have you considered just tossing in a cluster from an Explorer/Navajo that already has the tach? It's a drop-in swap that doesn't require an extra gauge on the dash. You can probably pick one up for about the same price as your Sunpro.
mormon92
Pluto
Ford,Mazda
3.0L,4.0L
haha, i would agree with getting a cluster except i got it for free.
as far as the wires go, this is my first attempt at any wiring so im trying to find out which wires are the ones i need. Is the power wire from the radio red?
