Tax time overhaul?
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
Beautiful! Lmao. Now just remember how to put all those parts back in. I had to label stuff and bag it because its been apart so long.
Sent from my iPhone
84bluebronco2
13
Central New York
Got the new O2 sensors, new clutch guts in, trans up and bolted, and t-case bolted. Exhaust, starter, driveshafts, and crossmembers to finish the bottom.
Once the bottom is done, gotta build the motor back up, charge the battery, and cross my fingers...
84bluebronco2
13
Central New York
When installing the heads, my chilton's manual lists using an inch/lb wrench on my intake... recommended, or just go by feel? Most places near me aren't offering small enough wrenches...
wizkid00104
13
2.3L/5.4L
I think it is a good idea. Depending on the torque specs, you can use a small ftlb wrench, just multiply the ftlb reading by 12 to get equivalent inlbs. I know craftsman makes an inlb wrench. Where have you looked?
Sent from my iPhone
84bluebronco2
13
Central New York
I've found a few, but they are all 175 or more... the intake bolts say snug to 32in/lbs for the first turn. No way to do that accurately with a ft/lb wrench.
wizkid00104
13
2.3L/5.4L
Hmmmmm. Did you try autozone or advance auto for rental tools? Harbor freight?
Sent from my iPhone
84bluebronco2
13
Central New York
Advanced and auto have them, but only down to 90in/lbs. I'll check harbor though! Thanks!
wizkid00104
13
2.3L/5.4L
Check sears model number 31423. It is Craftsman 3/8" drive micro clicker torque wrench 25-250 inlbs. On sale for $63.
Sent from my iPhone
Mac
183
C. Wisconsin
2000
199
NO,No, No. Divide the in-lbs required by 12 to get the right reading on a ft-lbs wrench. My good Craftman ft-lbs only goes down to 25. My in-lbs goes down to 25 in-lbs. Hot Rod Mag just did a great comparison of Snap-On and the Harbor Freight version and they were with less than a 1% difference. May not use it every five years but it'll still be good.
Dave
wizkid00104
13
2.3L/5.4L
My bad on the conversion. I should have written it down first. Lmao
Sent from my iPhone
84bluebronco2
13
Central New York
Ended up renting one from Auto Zone for now. Should be working the truck more Monday.
84bluebronco2
13
Central New York
Nothing too much sadly. Rain and being a CDL A driver complicate issues. Got my fan clutch off the old water pump just to decide to buy all new parts, and got the new qater pump set in. Might be able to get back at it tomorrow or Saturday.
84bluebronco2
13
Central New York
Got the clutch masters swapped out, but I have a question on the line between the slave and master.... it's back in the truck with no extra kinks, but not exactly how it came out... will that cause any problems?
