- Feb 28, 2001
- 4,411
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
'00 5.0L Explorer with mildly upgraded 4R70W with 255k miles on the clock. I have several issues to work through like getting it to hold passenger side motor mount bolts on the engine block (many years of operation with broken bolts wore down the block, don't notice it with an AWD T case but you DO in low range reverse ), leaks oil everywhere, blowby, broken off water pump bolt in the block/timing cover, installing OBX headers, etc...
I pretty much need this running by early September for a tractor pull the wife wants to do (I'm not against this, it's done it twice before...), if I get ambitious enough I'd like to strip the engine down enough to do a quick hone and re-ring to help some of the blowby (one vacuum line is leaking oil...)
My main question that I haven't looked into is how to line up the cam sensor, I haven't dug in but it doesn't look too obvious, is it as simple as getting to TDC and lining something up?
That's the question for now, I've just put 50k miles on the thing and one water pump aside from the transmission repair and swapping to a manual T case...
