temperature gauge
TheOldRanger
6
I am trying to diagnose the cause for no temp reading on my ‘87 2.9 liter Ranger. I have installed a new thermostat and block temp sensor. I have removed the temp gauge from the instrument cluster. I have a multimeter and a continuity tester. How can I test the gauge itself? Thanks!
rusty ol ranger
2.9 Mafia-Don
7,526
Michigan
177 CID
Reinstall it.
Pull the single wire off the sender (you did replace the sender right? Not the sensor? The sensor is 2 wires and sends info to the ECM only, the sender is 1 wire and is only for gauge)
Take the single wire and shove a paperclip or something metal in it, turn the key on and ground the paperclip to metal. If the gauge pegs on "H" then the wireing and gauge are working.
TheOldRanger
6
Reinstall it.
Thanks for your help! The gauge passed your test. As I think you suspected, It was a bad sender.
rusty ol ranger
2.9 Mafia-Don
7,526
Michigan
177 CID
