On paper yes.
Real world? Doubtful.
#1 That tiny little box on the new ranger cant even fit 1800lbs worth of stuff. A 8ft box F150 could eaisly swallow its "rated" capacity plus more. Not to mention most new trucks generally seem to be rated closer to true capacity instead of grossly underated like the old trucks.
it has a hd d44. racked, i could put 3 k worth of weight in it easily. it would beat the holy living fawk out of a bullnose 1/2 ton or 100. did you see the frame? in the real world...a bullnose will break in half long before that chassis will... fold up like a cheap lawn chair.in 10 years of michigan winters....maybe not so true.
2- 7500lbs is going to be much more stable behind a wider, longer, bullnose 150 then behind a narrower, shorter, ranger. Not to mention the fact (assuming we go for max everything here) that bulls 351W H.O is going to eaisly outsnort a turboed 4 banger in the Revs trucks are normally in. I dont know why everything has to have such a ridiculious powerband. Assuming because the higher the RPMs, the more HP you can claim, and the better it looks in advertisements.
are you really this ignorant?...or just being argumentative just to argue?....
have you ever driven an ecoboost anything subjectively?
its a fuking ecoboost.
not simply a 2.3 with a turbo slapped on it.
it is direct injected with variable valve timing.
its 5 engines in one and manages diesel torque capacity via the overly complicated wizardry....
you plug in one item from cobb and it makes more power then any 80's engine. dont even have to get your fingers dirty.
351 ho.....yeah...the ecoboost makes more torque from 1500 to redline then a 351 ho.
205hp ho 305-310 tq@ 2600..
it has better suspension and frame rigity by magnitudes andis about the same weight....it will tow the same load much better...
3- With the exception of the 80-82 100/150 swiss cheese frame trucks, the chassis on any older 1/2 ton is going to be much more suited to day in/day out rigors of hauling a 7500lb trailer. Not to mention the difference in utter strength between a C6 and whatever the new ranger has, the difference between a 9in rear and whatever is in the new truck, and the Ibeam vs coil over.
So yes, on paper. But i highly doubt 30 years from now many 2019 rangers will still be around earning their keep like i see quite a few bulls still doing.
New isnt always better.
new isnt always better...ok. we agree there.
the chassis of any 80.s 1/2 ton isnt shit compared to this critter...new for new...different galaxies.
corrosion on the other hand....yeah...i am skeptical of steel metallurgy being a bad idea..... but maybe its the good stuff....wont know for 5 years or so...
that transmission would murder a c6. you put them back to back...stock for stock...the case on the c6 will explode. uber strong.
the rear axle is better then any factory 9 in...
and brakes....the braking capacity alone makes this the preferred unit to tow with...of course the brakes on the bullnose are ok since it could never tow as much as fast as this thing will...
i beams??? yeah.....beams for the win.
