The 2019 Ford Ranger is yesterdays F-150
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,833
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I know that salt plays havoc with aluminum. Those who operate aircraft and helicopters avoid salt like it's the plague because of it on surfaces that they operate on.
Bird76Mojo
1,266
IL
Don't forget:
"It has been brought to the attention of the U.S. Army
> Aviation Missile Command (AMCOM) Depot Maintenance
> Engineering Team that numerous units are using the
> commercial product SIMPLE GREEN as an aircraft wash.
> STOP! This product has been through Department of Defense
> (DOD) testing and was determined to be highly corrosive
> on aircraft aluminum and also a catalyst for Hydrogen
> Embrittlement in high strength aircraft alloys."
Just for everyone's future reference...
GB :)
3,614
Don't forget:
GB :)
Yikes!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i have stated that aluminum most assuredly rusts. well...it doesnt "rust"...it corrodes.
as a guy that disassembled humvees and worked on lot of cruisers....they for sure rust.
sgtsandman
12,833
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Don't forget:
GB :)
I did not know that. Not that I use Simple Green to wash vehicles but still good to know.
Ranger850
Doesn't get Sarcasm . . .
4,701
Tallahassee Florida
Stock 2"
Stock
Animal crap, especially when mixed with their urine, will corrode the heck out of a truck in short order. Sticks and corrodes badly. It speeds up a natural process quite a bit.
I used to manufacture industrial farm animal equipment, so I'm used to seeing the effects animals can have on various metals. Even aluminum and stainless aren't immune to the effects in certain applications.
GB :)
This is true. Some bridge failures have been attributed to pigeon crap corroding the steel beams on the underside, causing collapse.
Ranger850
4,701
Tallahassee Florida
Stock 2"
Stock
the oxidization of metal is commonly called "rust". When aluminum "corrodes" it is the same as oxidization, which is the same as rust. Aluminum just takes longer to be effected by oxidization. Steel or iron rust is red or brown aluminum rust is white.
Bird76Mojo
1,266
IL
Don't forget, aluminum is also "protected" by an oxide layer. When that layer is removed (polished/sanded/or weathered) a new oxide layer has to form due to oxygen having direct contact with the aluminum molecules. This oxide layer is actually pretty tough in the grand scheme of things, which is why it usually has to be mechanically removed from aluminum before welding, etc. Sure, some use a mild acidic solution...
Aluminum corroding (severely) really accelerates at a certain point. When that oxide layer gets thicker and rougher, it then holds corrosive fluids, salts, minerals, easier, which further speeds up the process, making the layer even thicker, possibly even minutely flaky, ehich then holds more material. Although that takes many, many years in most cases. A clear coat over the aluminum can also speed this up by holding material under it once it starts cracking/chipping. You see this on rims/wheels quite a bit. It really is similar to steel in the way it corrodes, but on a much finer visual/molecular scale. We see this often on aluminum intake manifolds and old aluminum distributors at the junkyards. After cleaning or blasting we're left with large semi-circular pits as a result. Being in constant contact with water really accelerates this as well. Especially salty or hard water.
GB :)
Ranger850
4,701
Tallahassee Florida
Stock 2"
Stock
And that is the ALUMINUM 101 CLASS for the week. I hope you all took notes.
Did we have the same welding instructor, Bird76Mojo? Because I learned a lot of that from learning how to weld aluminum.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
well...after what i have seen today...i will refrain from cheerleading.
damn you rusty.....:thefinger:
fastpakr
2,849
Roanoke, VA
What happened today?
17,998
SW Iowa
You can't just drop that nugget and run away. :buttkick:
rusty ol ranger
2.9 Mafia-Don
7,746
Michigan
177 CID
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
well...after looking at it up close i had reservations.
looking into the reservations...i was able to get details.
so now....i will be patient. based on the issues with all of the new fords we have been through the last 4 years....i am not as sad as i was previously about not getting one of these to hack up in jan...
for 90 percent of people my issues are not issues.
sgtsandman
12,833
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
My caution is on the engine based on what I've seen with the Focus and Mustang with the same engine. Everything else seems to be pretty solid from what I can see in my research. Worse comes to worse, I have the 2011 Ranger to fall back on if the engine does indeed develop a problem and need recall/warranty service.
