Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
- Aug 2, 2000
- 8,798
- Nocona, Texas
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 / 2.3 Ecoboost
- 2WD / 4WD
- 4WD
- Total Lift
- 6-inches
- Tire Size
- 33x12.50x15
Things have been crazy, but I need to get this thread caught up.
I purchased a 48-inch Hi-Lift jack and a JackMate to go with it. At this time, nobody makes a winch bumper for the 2019 Ford Ranger, but I know that the combination of the Hi-Lift jack and JackMate should be able to get the Ranger unstuck from about any situation. You can only winch a truck a few feet at a time with a H-Lift, but it's better than being stuck.
I already showed you how I was setting up the bed.
Since I can't drill any holes in the bed, I took a sheet of 7/16" plywood and cut it to fit the bed, and then doubled up a section where the Hi-Lift would go. I used (2) 1/2" carriage bolts stuck through the bottom of the plywood and secured it with a washer, lock washer and nut. Then I added two nuts with a lock washer between them to serve as a spacer. The foot of the jack rests on the plywood. The rest of the jack sits on the 1/2" bolts. It's held down with a washer, a rubber washer, and a wing nut. The rubber washer keeps the wing nut from coming loose.
I have a Contico storage box held down to the plywood with (4) carriage bolts.
I purchased a set of X-Bull Recovery Tracks to use before resorting to winching. I bolted them to the front of the Contico box, and used the washer, rubber washer, and wing nut setup to secure it. I've used that setup before, and know that it works.
