The legendary 2.9 Free Floating Rockers
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
First of all, kudos to you for going down the rabbit hole on 2.9 performance. I abused the hell out of my 2.9, and it screamed along at 5,500 RPM for a very long time before I swapped it out. They're a better motor than most think.
Second, 2024 Al would work. BUT get me REAL dimensions of what you want, I'll whip something up, don't worry about the stock. ;) They'll be one off parts, but I'd worry about proving the their of free floating rockers before I worried about a modular kit.
Third, let me see if I can scrounge up an FE rocker from a buddy of mine.
Wait, really?? You'll turn a set out if I can pass along the dimensions??
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Yup, I want to see if this will work. Never wanted to tear down my 2.9 long enough to mess with it myself, but was always curious
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Went back and read through some of what you've posted.
You measured the 4 spacings as such:
2.129"
2.044"
2.016"
2.151"
Correct? Not trying to be a jerk, how much faith do you have in those measurements? You very sure about those?
According to the Kunz article, you want 0.020-0.030" clearance from the shaft to the rockers, which gives me a +/-.005" window on the length of each, which buys you a little forgiveness in your measuring, if I hit nominal.
That said, subtracting 0.025" from your above numbers gives me:
2.104"
2.019"
1.991"
2.126"
All +/-0.005"
Agree so far?
I see you listed rocker shaft diameter as 0.880", correct? The rocker arms need 0.0025-0.003" of clearance per Kunz, I can probably do that same for the spacers, although it is less crucial. Target would be 0.883" correct?
What's the outside diameter of the springs? Trying to figure out how large the OD of the spacer can be.
Numbers in green are the dimensions I'll be cutting to if you agree.
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Just double checked, I have an 11" long piece of 1.5" diameter 6061 in my box. Doubt 1.5" will fit, could spin it down to 1.25"?
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Talked to my FE guy, he's familiar with the 2.9 engine and says he's thinking the FE rockers are HUGE compared to the 2.9, but will get me a diameter and overall length for comparison sake.
Quick google search says factory 2.9 is 1.47 ratio, Morana ratio is 1.55, FE is 1.73. Probably a dead end.
I wonder how feasible it would be to bore out a rocker, and add an eccentric sleeve, to move the pivot location? Might have to undersize the rocker shaft to do it. Would be a very time consuming project and results may be small.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Where have you been my whole life.
I'll update dimensions for the 89tm rockers on my truck. Guessing their dimensions will be different.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
As much as I truly love insulting your insane, ridiculous, absurd, and baffling 2.9 obsession... You really should make a page with all your logs of this kinda crap. What works, what's failed, good, bad etc. It's all nonsensical rambling... but its interesting nonsense and I shamefully do admit I admire your conviction to this illogical endeavor.
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
snoranger
Professional money waster
ASE Certified Tech
13,676
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Let me sum up what you said in a meme for the younger generation...
31560
8thTon
--- Banned ---
806
Pennsylvania
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Is that where you bury the 2.9s? How fast do they sink, and can you still hear them tapping down there when it's quiet?
That's where you no lift shift that 2.9, 2nd to retreat at 5500 rpm waiting to see which parts scatter first. The answer is none.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Ok, so I'm sick with what I assume is the black plague, and I'm probably going to die, but I managed to get out of bed long enough today to check my current set of 89tm rockers:
Pass front 2.183"
Pass rear 2.040"
Driver front 2.036"
Driver rear 2.150"
All spring clips seem to have 0.100" between the rocker arm and roll pin
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Pass front 2.183"
Pass rear 2.040"
Driver front 2.036"
Driver rear 2.150"
Perfect, this is lining up to be a busy week, I'll see what I can come up with
