Throttle Body and Accelerator Cable
sanderthomas
4 L V6
Hi all. About a year ago I had to replace the upper intake manifold gaskets on my 1998 Ranger. It took 4 long nights (Had to wait for my son to go to bed) but when I tightened up the last nuts and bolts, she fired right up. The thing is, she stalled and ran rough, with a marked decrease in power. I've always had problems with the acceleration seeming to take a split second to kick in (at a stop light I'd hit the gas but it seemed to take a minute while the engine seemed to think about going before it took off), but this was different. Since I couldn't seem to figure out how to tighten the accelerator cable, I adjusted the little bolt on the throttle body that hits the strike plate. A little more salient information: I was a little confused at first when I removed the throttle body for the gasket replacement job, and I wound up taking the springs that control that little arm (as well as the arm itself) off, not knowing that I could just snap the cable off and have done with it. Anyway, she still runs rough and seems to have a lack of power. It seems like this should be an easy enough nut to crack, but my experience and know-how (as acquired through Mr. Chilton) only goes so far.
Any thoughts folks have would be appreciated.
Thanks!
dylanS
Rolla, Mo
built 4.0
i had the same problem with my 93 ranger and tried the throttle cable mod and it helped but not as much as i thought it would. I went to the local ford dealership anjd got a new throttle cable and it is running like a top again. i really doubt that u cracked that screw sounds like a frayed/stretched cable to me. not sure if its ur problem or not but thats what it sounds like to me
p38fln
Superior, WI
3.5 L GTDI
I kinda left the vacuum hose off that goes from the evaporator canister to the intake manifold when I replaced the gaskets on my intake - it ran like crap, and stalled at stop signs, shifted hard enough to chirp the tires, and still gave the P0171 code when I plugged in the scanner :)
Soo - are you getting any codes?
