Wanted TIB Sway bar endlink brackets.
turbo91xlt
63
Goshen, NY
1992
Looking for a pair of the brackets that bolt to '89+ 2wd twin I-beams that the sway bar endlinks attach to. Thanks!
NakedDucks
63
B’ham AL
I have a set. Yours if you wanna come get them.
NakedDucks
63
B’ham AL
Let me get the truck apart.
NakedDucks
63
B’ham AL
One is good and one is not.
I may can get you a matching set this coming week. Want me to check?
turbo91xlt
63
Goshen, NY
1992
If you can get a set that be great! Theres a bunch here in the yards but they put the stands under the radius arms so its nearly impossible to get the main bolt that holds the bracket/beam/radius arm/spring out without having the truck fall on you. And that's providing you can even remove the bolt from 20 years of NY rust...
NakedDucks
63
B’ham AL
Ok. Give me till this weekend. If you haven’t heard back in a week, hit me again on here to remind me.
NakedDucks
63
B’ham AL
No luck. There was only one in the yard, and it was missing the front end.
NakedDucks
63
B’ham AL
I will keep looking.
jjfugler
TRS Member
5
Baton Rouge, LA
Ford Bronco II
The Cologne'
How difficult is this to remove? I have one on an 87.
