tick under acceleration
bmxnick7
ranger xlt
well my truck has the typical ford tick under acceleration, how do i get rid of this, motor has about 140,000 on it.
phybere
Higher octane gas? My truck was doing this, and burning transmission fluid at one point, the cause was the transmission modulator valve, now I can run 87 octane again. Check the hoses to see if any of them are saturated/soggy with fluid.
bmxnick7
ranger xlt
thanks i will try that
89_Black_Beast
PA
89'
make sure you don't have an exhaust leak...
Royawest
Northwest PA
Mazda
My 4.0 was knocking while under load and I traced the problem to the egr system.egr was clean but the sensor was bad.changed it and no more knock.Plus much better gas mileage.
Yellowsplash
11
Morgantown, WV
Higher octane gas is just a bandaid. These engines were designed to run on 87 octane. Alot of times the tick can be resolved by cleaning the MAF. You can find CRC Mass Air Flow Sensor cleaner at your local advance auto parts or auto zone. Costs roughly $5-6 a can and wont hurt the airflow element like carb cleaner potentially can. Just clean it every oil change to keep your vehicle running top notch.
Secondly, I would run a can of seafoam in the engine to decarbonize the intake runners and combustion chamber. Just run a can through the brake booster vacuum line. You can find directions on here by using the search function.
Third, if your problem still exists, I would look into finding a vacuum leak.
As the other guys have said, it is also possible that it is an exhaust leak. You can usually spot one by the black silt deposits around the problematic area. (collector flange, egr tube, etc..)
