to the guys who have 91 4.0 5spds
Virginia
Ford Bronco ii
What is the ecu number you guys used or did you have good luck at a junkyard. At the parts store it doesnt show a list for a manual 4wd. Just 4 automatic 4wd numbers. If any of you guys have a stock 4.0 5spd 4wd id appreciate it if you could give me the numbers.
Earl43P
38
Farmington, Pa
Ford F250 4WD
Virginia
Ford Bronco ii
Thx a lot. Ill check out the links on lunch brake. n i agree about the 4wd bit. Switch to control module in the extd cab portion to tcase motor
Virginia
Ford Bronco ii
The page had been removed from the link. It apparently sold
Virginia
Ford Bronco ii
No one out there has a 91 4.0 5 spd?!!
kunar
131
Toledo, Ohio
5.8l
im running one from a 91-92 explorer 4.0, 5sp. code is x2x2. supposedly they are programmed to have a little stronger low end since the explorer had more weight over the rear. i put it in when i did my 4.0 swap so i dont have a comparison, but it runs my 4.0 just fine.
Virginia
Ford Bronco ii
I found a chilton manual. Figurrd out why my 93 ecu wont run my truck worth shit. They changed pins around and added egr, 2 o2 sensors, and cam sensor. 91-92 pins r the same.
Virginia
Ford Bronco ii
Taragon
4
Alabama
4.0 and D60's F&R
1991 Explorer 4.0 Manual Transmission 4x4
Calf 3006 (F07F-12A650-YA) & (F07F-VAMR)
Fed 3007 (F07F-12A650-VA) & (F07F-VAMR)
1992 Explorer 4.0 Manual Transmission 4x4
Calf 3397 (F27F-12A650-VC) & (F27F-12A650-VCMR)
Fed 3398 (F27F-12A650-TC) & (F27F-12A650-TCMR)
1993 Explorer 4.0 Manual Transmission 4x4
Calf 3729 ( F37F-12A650-XB) & (F37F12A650-CRA)
Fed 3726 (F37F-12A650-UC) & (F37F-12A650-YR) & (YMBR)
1990 Ranger 4.0 Manual Transmission 4x4
Calf 3064 (F07F-12A650-P1A)
Fed 3065 (F07F-12A650-M1A)
1991 Ranger 4.0 Manual Transmission 4x4
3065 ( F07F-M1A)
3256 (F17F-ADA)
1992 Ranger 4.0 Manual Transmission 4x4
3433
1993 Ranger 4.0 Manual Transmission 4x4
3723 (F37F-LA)
