TOO much positive camber 87 BII
groovtubin
29
NC
Ford Bronco II
Anyone have advice on how to remedy? Ive seen one utube video @ a adj nut on bottom ball joint, anyone ever done this? Pax side is way worse than driver, Thanks in advance!
scotts90ranger
4,489
Dayton Oregon
2.3 Turbo
Adjusting that changes the toe as well, I could go into detail but don't have much time right now, it's basically loosening the top pinch bolt and pulling the top nut or snap ring or whatever (been a while since I've looked at a D28) then lifting the adjuster and moving it over a notch or two.
I would first look at the toe setting, if it's towed in it will go that way too...
groovtubin
29
NC
Ford Bronco II
Thank you so much for info n your time! God bless !
groovtubin
29
NC
Ford Bronco II
Thank you so much! Sporeciate your time. God bless!
ericbphoto
Overlander in development
16,744
Wellford, SC
3.0L
6"
