tool used to install Bushings
duce07
Missouri
If you can't keep up- Don't get up
ok got new Dorman shackle's and Spring hangers for the 99 Ranger ,my old ones were rusted and falling apart, cleaned out the spring eye but I dont want to take my springs off the truck SO what is the easiest and best way to press the new bushing into the spring ???
Thank for any help
I was able to use a ball joint press for my rear spring bushings. The forward ones it wouldn't fit around.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
ball joint or shop press on its side under truck. which is dangerous as hell..
from there various smoke wrench scenarios...
alwaysFlOoReD
5,104
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I think I would try some all-thread, a bunch of washers, and a couple of nuts.
